I need amplifier
sasi_999
india
Sony Hi-Fi Music System DHC-FLX9W
120W x 2 + 240W Supplied Subwoofer RMS (At 2.1 Ch Mode), 5300W PMPO
60W x 5 + 120W Supplied Subwoofer RMS, 4400W PMPO
Speakers
-Front: 13cm x 2 H.O.P. Woofer + 5cm Tweeter
-Centre: 5cm + 8cm
-Rear: 4cm + 8cm
-Sub Woofer: 18cm...
THE MAIN UNIT IS NOT WORKING SO I WANT GUD AMPLIFIER WHICH SUITS,IN ANY BRAND ....COST UNDER 20,000 PLZ SUGGEST MEE WAITING FOR U R REPLY .TANK U IN ADVANCE!!!!!
Speakers
-Centre: 5cm + 8cm
-Rear: 4cm + 8cm
From what is written above, it appears that you have one Single box stereo / HT system along with a 2.1 speaker setup (120W x 2 + 240W Supplied Subwoofer) and a 5.1 speaker setup (60W x 5 + 120W Supplied Subwoofer)
Kind of confusing as to how you are using the setup. Can you explain a bit more.
I think the Denon 1311 for 22K, will use your main 5 speakers. However, you will have to look for a powered subwoofer (used 6k-9k on forum, 12 to 18K new, to connect to the amp, and junk your existing sub.
Cheaper- Alternate, you can buy a Yamaha, Onkyo stereo amp for about 14-16K, and run the cables thru your sub, to your main speakers (fronts only) and chuck the rear left and right and centers out.
Either ways, you going to buy something new, and chuck something old.
All the best.
I saw an ad in yesterday's (24th Oct) Times of India. Onkyo Home theatre HTS-3100 selling for Rs.17K. Don't remember whether it was in Reliance digital or somewhere. You can check the online version of TOI for details.
I would say, Onkyo will any day sound better than a Sony all-in-one system.
So strongly recommend to grab the Onkyo before the discount goes off.
i saw an ad in yesterday's (24th oct) times of india. Onkyo home theatre hts-3100 selling for rs.17k. Don't remember whether it was in reliance digital or somewhere. You can check the online version of toi for details.
I would say, onkyo will any day sound better than a sony all-in-one system.
So strongly recommend to grab the onkyo before the discount goes off.
hypercity. 16990 :)
Speakers
-Front: 13cm x 2 H.O.P. Woofer + 5cm Tweeter(rated impedence 8 ohms)
-Centre: 5cm + 8cm(16 ohms)
-Rear: 4cm + 8cm(6 ohms)
i have contacted nearest home theatre he said go for deonon 1611(28 k )5.1 reci
and power sub frm polk 10 inch( around 11- 12 k) ....
so im thinking whether to go for it r not
shall i go for onkyo TX-SR508(28k )7.1 rec...
i want gud sound frm music and also movies
so which one shud i prefer ...
Speakers
If you dont need HD Audio in Movies, Ezone selling old models @ 50%.
i want sell my PM 7003 Marantz Amp use hardly 1yrs for 20k
Why don't you start a 'For-Sale' thread stating CORRECT number of years used instead of putting this info everywhere? You need to take snaps and post them.
Btw, It is not 1 yr used but close to 2 years from your earlier posts.
http://www.hifivision.com/speakers/3428-dali-ikon-6-marantz-pm7001-2.html#post80929
You have already stated 6 months elsewhere and someone pointed out the above post. I request you to me more sensible while posting.
