Jamo s 506
R Narayanan
New Delhi
Hi guys. Can anyone please tell me some thing about the Jamo S 506 floor standing speaker. I heard this recently with a friend and thought this was fairly musical and impressive in other aspects as well. But I need an audiophile view.
If any of you have sampled this product please let me know what do you think....
the following are the specs
Frequency Range (Hz) 45-20,000
Impedance (Ohm) 6
Overall dimensions (mm/in, HxWxD) 1000x195x301 / 39.4x7.7x11.9
Power (W, long/short term) 130 / 180
Sensitivity (dB, 2.8V/1m) 89
System Type 2-way bassreflex
Tweeter (mm/in) 25 / 1
Weight (kg/lb) 15,2 / 33,1
Woofer (mm/in) 2 x 165 / 6
thanx a ton guys.::)
I have a pair. I did an upgrade crossover using better caps & aircore inductors. I could hear the difference straight away using 12g wire. They have nice smooth bass, good mids with the mid phase plugs. I changed the capacitors on the tweeter to improve its performance. The crossover is OK as is. Just get a better poly cap with a bypass 0.1uf cap in series with it. You will love it.
