LED 4K UHD TV - 49" or 55"
uda2k2
I'm looking for a 4K UHD in the range of 60 K, and finalized the below models, my usage would be mostly on DTH (SD Channels), Amazon Prime & Youtube. Please could someone suggest what size would be ideal for my needs 49" or 55" from the below models? Thanks in advance.
1) LG 7300
2) VU Android Premium
3) Sanyo Kaizen
Please could someone suggest which model should go in the budget range of 60K?
VU Android Premium or LG 7300?
Kindly suggest. Thanks in advance.
55 inch is the minimum for far field viewing. If you maintain a distance of at least 7 feet between the tv and yourself, I would recommend going for 55 inch or more.
