Looking for Portable Bluetooth speaker? you can check out x300 confidently.
netant
Bought Logitech X300 last week, cant be more happy. Crystal clear audio output, 100% meant for Vocals, country & jazz music, Rock/metal wont sound satisfying.
My personal view after audition of multiple speakers in same environment and same source and same songs, before opting for x300.
x300 deliver better sound than other expensive Logitech's model tested
UE Boom2 - so-so sound at super high price
UE Boom Roll 2 - don't touch it even with 10ft stick. unless you want a BT speaker to take inside water/pool.
Anyone looking for BT speaker at 3-6K budget range, look no further X300 is the thing you want, I got it @2999/- against 2.5k general pricing, thanks to GST :(
  • If the budget is less than 3K, check out SoundBot & Zook rocker - good soung for the price.
  • If your budget is between 6-10K, Sony SRS-XB20 is the winner ... when i heard this after listening UE Boom2 i was blown away, boom2 sound was muddy and muffled.
  • If 15+k, check out Bose SoundLink Mini II
If i had budget i would have gone for SoundLink, the only issue i have seen in Bose is, when in high volume, volume will automatically reduced when playing bassy/low frequency, but will maintain the quality of music(all frequencies).
Where as in X300, in high volume bassy track, high frequencies will be cut but volume will be maintained.
Another difference between X300 (personal rating: 6/10) & soundlink(personal rating: 9/10) is the sound-stage, Bose sound-stage is phenomenal compared to any other mentioned in this post.
i hope this helps!
fell free to ask any question if you might have.
i hope this helps!
I would like to add Bose Revolve If your budget is close to 20k, I personally felt Bose sound link mini has low volume but sharp hence good for use in inside quite room but for outside bose revolve is good and yes Sony xb20
