hmmm.. - rupiah se rand
i think its about getting used to as well..
maybe the way i put it implied i was looking to now play with the amp - thats not the case at all. I only wanted to highlight the bass diference i am hearing and
difference gets perceived as
deficient unfortunately. :lol:
sorry if it appears that way.
hope things are well with you.
:cheers:
mpw
Hi Mahesh,
Had got what you were saying. wrote what i did from a perspective that different is probably better and better almost always intially sounds "less"
I know that this thread has got hijacked into a bass discussion rather than your feedback on your new speakers, and i'll be guilty of just one more transgression.
if you ever have the time and inclination, i'd suggest you try them in a 120-150 sq ft room. I am pretty sure different will then sound "wow"
secondly, for some one as particular about "his sound" as you, a sub or two is going to be a bagful of hurt. whenever you do eventually choose to do it. I would've recommend passive with a high efficiency pro audio type woofer in a smallish sealed box with a bag-end-type filter to bring it in line, but either you'd need to ensure amp stability in 4ohms in the bass region or high pass your bookshelves and lose efficiency.
Active is even worse. the only commercial offering that I believe can match accurately would be rhythmik 12" woofers. Done wrong, you'd lose a lot of what you like about your speakers, while gaining not much.
lastly, if we ever had an "accurate bass" sweepstakes, my vote for first place would be a damped TL, which completely absorbs the backwave. B&w Nautilus and giya G series are commercial examples. Infinite baffle would be next. I haven't heard much of Open baffle to comment. as for the sealed versus vented debate, I believe that a well designed bass reflex with the right woofer can sound as tight and clean as a well designed sealed, with more deep bass, more efficiency and the negative artifacts (group delay) pushed well into the inaudible range.
hijack over.
edit: Hari - bass roll off - sealed is 2nd order (12dB/octave) and bass reflex is 4th order (24dB/octave)
