Ghatgepatil, mpw has a huge room. Its probably 500 sq.ft or even more. In his house its only an aesthetic issue. He can even get the speakers out by another feet. I think in his case its not 3 ft or 5ft or 6ft. Its either 15 inches from wall or the best sounding position
GP,
the room is 20 by 20 & the rectangle in which we sit is 20 by 12. The other 8 feet width is a common area between 2 flats which are combined. I will try and post of pic of my room from the other side later.
as prem says - its either the place where it was or the position that sounds best. Hopefully things will develop into the latter option.
What is coming out of all the experimentation done on the Eposes and the Merlins is that to get the speakers to lock in and get that sound :-
a. space from the back wall and side walls are important. This can be even more important than simply moving up the listening chair near the speaker.
The movement of the listening position near the speaker will not be of much use as the speakers are still getting muddied by the back wall anyways..
b. reflective surfaces like glass tables etc.. need to be replaced with maybe wooden surfaces or substitutes etc.. or eliminated
c. apart from speakers specifically designed to operate with rear wall support or speakers where some form of electronic compensation ( software / hardware ) is used.. all speakers need space from the back and side walls to lock in. ( be it sealed or ported be it standmounts or floorstanders )
Once the lock in happens.. it is very difficult to go back to the original speaker position as in one keeps thinking of what is possible with a given speaker / system - provided there is adequate space for it to interact with the room.
This actually opens up the question - of smaller rooms and larger speakers.. and that's something which I haven't experienced much so cant comment on it save to guess that the speakers would need to be placed along the diagonal.
One may hear good sound in the room but one needs to try and get to the point to hear what the speaker is capable of. This could be 2 different things.
From sounding good to sounding great !
mpw
