I am planning to buy WD live from US which is available at $62 on Ebay..Is it worth buying OR should I look for ny other option ?..Plz advice..
WD TV LIVE WDBAAN0000NBK HD Media Player | eBay
Will suggest you to go for some player which is locally available.Try Himedia or Kaiboer both are good options.
Thanx mrigesh..Are both the player available in India? what is the price? and what is the major advantage compared to WD live?
Hi all,
My 8 month old WDTV live went dead last week while i was playing a video. Purchased from amazon through shop your world. It doesnt give any signal out. TV just shows like there is no device connected. Doesnt respond to remote keys. The power display in player is shown as ON.
Has anybody faced similiar issues. Tried resetting but didnt work out. Does WD provide support to imported media players.
Thanks in Advance.
Antony.
WD provides stellar support for imported HDDs.
Hi, would there be a difference in SQ if streaming FLAC files using the WDTV directly to the amp or via a DAC to the amp.
I am looking for a streamer to play FLAC files from the Harddrive. How about the Xtreamer or Asus O play?
Welcome any suggestions or alternatives. Thanks
