Hello FMs,
I am planning on a DIY full range speaker setup for my PC. Will be running it off my Vintage Cambridge Audio A1 Mk1 amp. Currently using a old Bose acoustimass series 3, 2.1 setup. Planning on using the Dayton Audio-RS100P-8 4" (available at diyaudiocart dot com) would have preferred the PS95-8 3-1/2" Point Source Full Range Driver, but is out of stock in the website. Would connect it thru the Acoustimass sub which has a Nominal impendence of 5ohm and handles upto 2x50w speakers. Box size planned 235x141x90mm front ported (35mm). Need views/help in following questions:-
1. Do i connect the speakers directly to the PC or can i connect it thru the acoustimass (hope to get some bass). will there be any issues due to the 5ohm impedence of the sub.
2. Would the box size and port size suffice. what should be the length of the Port tube.
3. Where can i source the PS95-8 online in India, or is there any better in the same price range.
4. I will be making the box myself. should i use mdf or plywood would do. what should be the ideal thickness of either.
Please do suggest. thank you.
(ps. i am a commerce type and dont understand the various cct diagrams/ qts, mts and the like but am a hobbiyist and will try my hands on any diys )
