Need Help In Buying 32"/40" LED Tv
sumantagrawal
Jalgaon
Hey Friends,
I want to purchase a LED fullHD Smart Tv in 32:/40"
Requirements:
Full HD1080
Built in wifi
excellent refresh rate of 120hz or better
min 2HDMI port and 2 USB port
if possible usb to usb data transfer
Hey Friends,
Requirements:
Full HD1080
Built in wifi
You did not mention any budget.
U can try out Samsung Series 6 UA32ES6200RLXL. It has everything you need (32inch).
If you do not need so many smart feature you can also try SONY BRAVIA HX750 if available at your nearest dealer. It has good refresh rate as well. I was really impressed by its 2D PQ in 32 inch. For 3D you can refer to LG models.
Otherwise for 40inch you can find SAMSUNG Series 5 UA40ES5600RMXL. Just pay a visit to your nearest shop...a lot of new options may come your way including PLASMA TVs which are undoubtedly superior to LED in PQ.
40inches please................do not even look at 32inches!!! Might have to stretch budget a bit but trust me it's well worth it. 32inches really is too small to give you anything, unless you want it for a really small bedroom.
Rather go for a simple 40inch than a fancy 32inch with all the bells and whistles. If you are open to plasma look for further............samsung 43F4900 is your best bet and will be better than most entry level LED tv's.
