W Series - KLV-52W400A
Sonys 52 (132 cm) W-series BRAVIA is a Full HD step-up model with stylish design which includes a wide range of features including BRAVIA Engine 2, Live Colour Creation and BRAVIA Sync, as well as PhotoTV HD and DM Port for viewing of digital media files.
MRP Rs. 199,900 /-*
LCD Screen Size
52 (132 cm), 16:9
TV System
M, B/G, D/K, I
Colour System
NTSC 3.58, PAL, SECAM, NTSC 4.43 (AV In), PAL 60 (AV In)
Video Signal
480i, 576i, 480p, 576p, 1080i, 720p, 1080p
Display Resolution
1920 x 1080
Video Processing
BRAVIA Engine 2
Panel Bit
10-bit Panel
Backlight Module
WCG-CCFL
Advanced Contrast Enhancer (ACE)
Yes
Theatre Mode
Yes
24P True Cinema
Yes
PhotoTV HD
Yes
MPEG Noise Reduction
Yes
Dynamic Contrast
33000:1
Panel Contrast
3000:1
Viewing Angle
178
Screen Format
Wide Zoom / Normal / Full / Zoom
Picture Mode
Vivid / Standard / Cinema / Photo
3D Digital Comb Filter
Yes
Power Requirements
110-240V 50/60 Hz
Power Consumption
280W
Standby Power Consumption
Less than 0.3W
Dimensions (W x H x D) with Stand
1262 x 871 x 347 mm
Dimensions (W x H x D) without Stand
1262 x 829 x 119 mm
Weight with Stand
38kg
Weight without Stand
32kg
BRAVIA Engine 2
BRAVIA Engine 2 incorporates full digital signal processing technology in all high-quality image processes, thereby maximizing the features of display devices and producing sharp, vibrant, life-like images. The fully digital video-processing circuit can reproduce optimal, high-resolution images from SD signals and HD signals.
More
Full HD 1080
With High Definition (HD) 1080 recording, the effective scanning line is 1,080, which is more than twice the number in conventional standard definition (SD) format, and video data quality of High Definition 1080p recording is about 4.5 times more.
More
PhotoTV HD
This new feature allows you and your loved ones to enjoy all your favourite images right on your BRAVIA TV in their full glory. Create a slide show directly from your Handycam, Cyber-shot or Alpha featuring your exotic vacation or a collection of images from days long past and enjoy them in the High Definition and colour of your BRAVIA TV.
24P True Cinema
While conventional televisions (and most DVDs) operate at 50Hz, modern film-makers record their films onto Blu-Ray Disc using 24 frames per second (24Hz, or 24P). With 24P True Cinema, your BRAVIA will automatically recognise these films and select the correct format for playback so you see and hear the film just as in the theatre.
Intelligent Picture
BRAVIA's Series is equipped with Intelligent Picture that automatically boosts weak analogue broadcast signals (RF) and reduces the noise of these signals to produce vibrant and noise-free pictures. Enjoy images of the highest clarity on BRAVIAs Series every single time.
More
MPEG Noise Reduction automatically reduces block noise and improves the edges of characters while at the same time, successfully suppressing noise that usually appears at high contrast edges. Enjoy crisp, noise-free images with sharp edges on BRAVIAs Series televisions.
BRAVIA Sync
BRAVIA Sync allows for intuitive one-push play and shutdown as it synchronises with all your other entertainment devices.
More
New S-Force Front Surround
Sony has developed the new S-Force Front Surround by improving the digital signal processor algorithm and the result is a wider listening area that delivers amazing virtual surround sound using just the built-in television speakers. Listen to every dialogue with the Voice Zoom function while maintaining the level of ambient surround sound and maximise your movie watching experience with BRAVIA.
More
Ambient Light Sensor
BRAVIAs innovative ambient light sensor automatically adjusts screen brightness to match the ambient light in the room and, as a result, saves on power consumption and reduces eye fatigue at the same time. Now you can just switch on your television and enjoy your favourite programmes in perfect colour and contrast automatically without having to adjust a single thing.
Wide Colour Gamut CCFL 2nd Generation
The Wide Colour Gamut CCFL (Cold Cathode Fluorescent Lamp) 2nd Generation improves the vibrancy and richness of reds, greens and blues and uses an additional phosphor coating for brighter backlighting. With an improved tri-colour enhancement, you receive richer reds, more natural greens and clearer and deeper blues for more detailed colours than ever before.
More
Picture In Picture (PIP) & Picture And Picture (PAP)
Watch two separate pictures from different sources on the screen at the same time!
More
Theatre Mode
Collaborating with Sony Pictures Entertainment, Sony has created Theatre Mode, Sonys authorised picture setting for films that accurately balances the colours of dark scenes and with the right amount of film-grain. You can now experience every movie exactly the way the director intended!
Revel in a world defined by vibrant and natural colours with Sonys Live Colour Creation technology. Live Colour Creation is the result of the synergistic effect of Sonys backlight
