NEED HTIB for Small Room around 20k
kyahaiyaar
delhi
Hello Friends,
i am Looking for a Home Theater system for small room(Basically gaming room).
1. My Budget - 20K
2.Devices to be connected
2.1 32'inch TV
2.2 PlayStation 4
2.3 Should have DLNA kinda feature for movie streaming etc.
3. It will be used 50% gaming (PS4) & 50% music.
4. Currenly i have been using Sony Dav-DZ340k which doesn't have an optical input and thus i am not satisfied with the sound i am getting it thru 3.5mm :sad:
for 20K you can only venture in to commercial brands like sony, samsung LG etc. HOw about LG HT855
Personally, bare min I would recommend for an HT on a budget is something like Onkyo HT s3500 or Yamaha YHT 196 .............. But both would be out of your budget, unless you can extend a bit .... :)
how much will they cost.. both yamaha n onkyo..n plz provide the link for the same
2.2 PlayStation 4
I am little confused about the requirement. PS4 itself should be able to play movies from your laptop/desktop through media server.
Regarding Music and optical output requirement, I doubt that at 20k there is any HtiB system which has better DAC than PS4.
My suggestion would be to use PS4 as source for both music and movies and look for entry level system like Onkyo HT s3500 or Yamaha YHT 196 as other FM has suggested. Yamaha 196 used to cost approx 25k sometimes back.
YHT 196 is available for 25k at infibeam....but will it be as powerful as my current sony dav-dz340k which is 1000w with super amazing bass..i am an audiophile... :o the only issue is it doesnt have optical input n i want 5.1 from my ps4 :sad:
What Brand Do you want ?
onkyo 3500 will cost you around 27-28k... Shop (Top Gizmo Noida, Onkyo wonderland Rajendra Nagar & CR park)
I tried to find onkyo 3500... But it was found that this particular model has been discontinued... Now 3700 comes n mostly all dealers have quoted 33k for 3700 model.
Reliance digital showcased yamaha 1810 model it was gud n they quoted 29k for it ..but is it worth it??.. I like onkyo 3500 too but since it is discontinued , I can't find it in delhi
So please suggest a good htib models available in delhi for 25 -30k..n preferably with emi option [emoji4]
So strange, or should I call it funny that the sony DAV-DZ340K that you have mentioned as capable of 1000W RMS will consume only 160w in operation.
Yamaha 1810 @rs 19000 is a good deal. I bargained for it at reliance digital kolkata, but their price wont get below rs 31000.
Go for Yamaha. For 19 k it's good. But if you can extend nothing beats onkyo 3700 for 30 k.
Budget was the issue...can't shell out more.. So bought yamaha YHT 196 yesterday.. Will be delivered today by reliance digital... Will require the connectivity help from you guyz once it is installed.. ???
