need portable around 240" 16:9 ratio screen at pune
vragho
Pune
looking for cost effective, 240inch (diagonal), and portable projector screen for luxcine z4000 projector. Most of the time (around 10-20 hours per week either day or night) it will be used in club house and occasionally (100-150 hours per year) in open lawn. When not in use one should be able to either manually roll up or roll side (assuming folding is not option as it may create lines/wrinkles etc.) Suggest suitable options available in case any vendors supplying in India are available in forum they can suggest options here or message on +91-9881400819
First, i doubt if Luxcine Z4000 would fill a 240 inch diagonal screen with enough brightness.. What is your budget?..
240 inch diagonal is a massive size and that too portable would be a diffuclt.. Retractable screens for 240 inch will be absolutely heavy (if aval) to move around..
I think it would be best to consider maptype screen, (or) a screen that you can pin the corners to the wall..
Below image as example..
If you can find an appropriate wall, why dont you think about painting it for the purpose? Also for 240", you will need a really bright projector
