Need suggestion
jice505
Chennai
Hi Guyz,
This is Karthik from Chennai. I m thinking to buy speakers for my PC. (2.1 or 5.1 )
Suggest me within 5K range. I have few in mind
1. Creative Inspire 4500 and 6160
2. Altec lansing
Thanks in advance
:clapping:
Edifiers are actually a very new brand , people are more familiar to the sound of altec/creative .
Just my two cents - If going for a Ht setup , go for the most powerful 5.1 you can fit into that budget . Usually a weak subwoofer will destroy the benefit for 5.1 .
Look into philips home theaters too, yes they have powered HT's starting from 1800/- can be connected to Pc just like, best part is you can ask for the demo at stores like Croma .
as for 2.1 goes, i have yet to find a decent sounding 2.1 under 5k . the closest was Altec lancing.
altec lansing quality is crap these days. gone are those atp3/mx5051 days.
Creative doesnt produced acceptable sound(at least for me) under 5k price.
Only that comes to my mind is Edifier c2. Buy it u wont regret. its around 4k.
if 5.1 is you need(which meant solely for movies), dont look speakers under 10k. I recommend Logitech z906.
