Need urgent opinion and help
rachs
Dubai
I am planning to buy Denon 1312 amplifier and JBL scs400 speakers.
I don't know how far these two are compatible but I would love any feedback or criticism and any sort of help.
The two are going to cost me some AED 1400 which is around Rs. 20,000
Let me know if its a good system for a living room, where it would be used 60% for movies and 40% for music.
Thanks,
Rachs
Thanks,
Rachs
Denon 1312 is a good entry level receiver and will suffice for a small room. How big is your room? If you can stretch your budget a bit, suggest to go for denon 1612.........it comes with audyssey setup which auto configures the entire system. you can also listen to other speakers from wharfedale, polk audio, boston acoustics, etc............and then decide. Denon would match most of the speakers.
