For the life of me I cannot find where one can change the output resolution settings. Could you please tell me where in the menu to find this.
Also, Dish TruHD people continue to insist that they have Dolby Digital 5.1 sound, but I am not getting it on any of the HD channels. Thus, are there any settings in the menu related to audio output?
PS: BUYER BEWARE: DO NOT buy Dish TruHD. Undoubtedly the Dish TruHD set-top box and the user interface along with many other issues are absolutely pathetic and probably could not be any worse than what they are.
Step by step instructions for how to set the STB to output to to 1080i @ 50Hz
1. Press the Menu botton on the remote.
2. Press the left arrow on the direction pad once to take you to the Setup menu
3. Select "Picture Settings" using the up/down arrows of the direction pad. (Should be selected by default)
4. Press the Ok button on remote
5. Select HDMI Setting using the up/down arrow keys
6. Press the left arrow till you see 1920x1080i@50Hz
7. Press the up/down arrow to select SAVE
8. Press the Ok button on the remote
This should save the settings. You may also want to set the TV type to 16:9 at the same time. For some strange reason, the STB shows the TV type as 4:3 whenever I go into the menu while it is working in 16:9 mode.
As per the LG website, my TV is supposed to support Dolby Digital 5.1 decoding. But the TV only has 2 speakers and my laptop does not detect it as one that supports Dolby Digital 5.1 when I connect it using a HDMI cable. My laptop detects an AV receiver properly. Now in the program guide menu of the Dish STB, there is an option to select Surround mode for audio, but I do not see any difference with this option selected. The TV still shows 2 channel audio setup. Now I do not know if the problem is with my TV or with the Dish STB or with the Dish service. Once I get a AV receiver, I will be able to give a more definite answer to this.
-- no1lives4ever
