Is this a better one? Why some mention Made in England and other Made in U.K?Jenson, Aandhi Mausam is not the right press. You need the UK Press. Not the US. It needs to say PMLP. Not CDF. The other two are fine.
ThanksYes. This is the correct one. Made in UK are later presses. Early ones will say Made in England
Hi Jenson - can we get an update ? How did it go ?Got lucky with two more pmlp discs, both DP
0 new items by Jenson Joseph
photos.app.goo.gl
Chori chori/anari CD cover has cdf 1.2**** but disc has pmlp
Jagjit singh CD, too looks interesting while made in India... Is AAD.. Packed in 99 but disc mentions 89?
Finally, do I hear a difference... This weekend is judgement day
This was a great learning curve, truly appreciate @prem for all the guidance
for older films, PMLP/PSLP series definitely has a more organic sound. it's the best one can getHi Jenson - can we get an update ? How did it go ?
I am searching for a collection of old Hindi CD's ....any website you would reccomend ?
this is indeed very helpful Jenson. I will check the link - but you didn’t mention the name of the chap from Delhi ? or is he also identifiable in the above link ?
my bad.Jenson, it’s Surinder Khurana.
Did Made in England And Made in UK of same album has any change in quality?Yes. This is the correct one. Made in UK are later presses. Early ones will say Made in England
Did Made In England ANd MAde In UK of Same albums sounds same or differentYes. This is the correct one. Made in UK are later presses. Early ones will say Made in England
Kindly post your experience dealing with Vinayak music.for older films, PMLP/PSLP series definitely has a more organic sound. it's the best one can get
on some CD's the cover may mention CDF **** but the disc would be PMLP/PSLP. these are typically CDF 1. **** series. some of these are made in US too.
wherever the recording process is mentioned as DP, looks like it is copied from an LP, and it miraculously captures the essence of LP. AAD too is super great to have.
As recommended by Prem, definitely ignore Made in USA disc. no matter how lucrative the deal...better take the same from saregama.
i also got some made in India cd's which are either copied in DP or AAD format and from 90's, these too are worthwhile.
btw, pretty expensive route..but I guess worth it. even raj Kapoor soundtracks from 50's retained their magic. really happy with the suggestions by Prem.
finally, these cd's are the best possible version one can get in the digital format i believe, however, the recording process is no comparison to how let' say jazz was recorded in 50's...can't imagine how these songs would have sounded in that setup
Source:
facebook groups, - there are many. you will have to deal with lot of dealers...some are real sweet to deal with, some are as you'd expect. if you have lot of moolah then there is this gentleman from delhi, has a massive collection.. but prices range between 2500-4000 for pmlp/pslp series.IMPORTED AUDIO CDs Archives - Page 2 of 31 - Vinayak Music
vinayakmusic.com
Very professional. Pls note that these pmlp/pslp series are printed between 1989-1992 I believe (prem has mentioned elsewhere) so, expect grading to be between vg to mint.Kindly post your experience dealing with Vinayak music.
