Region Code Change For Nad DVD T514/524/531/571/L55/L53
afj
hyderabad
this helps the above dvd players play dvds from all regions. to be done from the remote
1. switch on unit, with tray closed, DVD display reading "NO DISC"
2. press pause, 314159. "CODE" appears on DVD display
3. enter the region code as 0 (zero)
4. Press pause to save
5. switch off the unit and unplug for the setting to take effect
now player will play dvds from all regions. hope it helps some of you
