Rethm Bhaava or something else under 2L
You could try line level attenuators
Don't know how far they will reduce
Search for Harrison Labs. There might be other brands too
Thanks for you response.
I was thinking that I will do sound IQ check in the amp. Which will calibrate the sound with each speakers.
Or Can I add some audio equipment to lower the wattage of my Onkyo amp.
I have lyrita pre power amp but I use them for my separate stereo system with Saadhna speakers.
I love sound of my Saadhanas. So though of replacing my atmos home theater tower speakers with Bhaawas.
Mr Viren say it will work. But I m still unsure I will get the sound as per stereo system.
Talk to jacob.He used to do a matching center before.The tonal quality of the front and center should be same to give a better theatre experience.You can even go for the arkas and use avr volume control.
