Rip Blu ray to MP4 to Synology DS416 NAS
Velemoochi
usa
This article shows you an easy workaround for copying Blu-ray to Synology DS416 NAS via Mac 10.11 by ripping Blu-ray to Synology DS416 friendly video format.
Synology Inc. announced the release of DiskStation DS416 and DS216play on Oct,09,2015. NAS servers designed for optimized task processing. While DS416 is equipped with a powerful hardware encryption engine and featured-rich/high-performance NAS server optimized for businesses and homes. You may have purchased a new Synology DS416 NAS to store all your media files on it. Besides streaming music, photos to your iPhone, iPad, HD TV, etc media players using the NAS software, you can also copy Blu-ray movie to Synology NAS for easier streaming.
In this article, we will teach you how to get Blu-ray to Synology DS416 NAS via Mac OS X El Capitan easily and keep the best video quality.
Hot Search: Best Blu-ray Player for Mac | DVD onto Synology DS216play | DVD Movies on QNAP NAS | DVDs on NAS to Xbox |
While, Synology DS416play NAS cant support Blu-ray files. To put dozens of Blu-ray movies to Synology DS416play NAS device for storing or streaming, you may have to rip and convert Blu-ray to Synology DS416play via OS X El Capitan compatible MP4 or MKV format first. What you need is a professional Blu-ray ripping tool that supports converting Blu-ray to MP4/MKV for NAS with the best quality. Pavtube BDMagic for Mac is just the right solution for you. Read the review.
With it, you can convert Blu-ray to almost all regular video formats like MP4, MOV, MKV, FLV, WMV, AVI, etc. without quality loss. audio from Blu-ray movies. Best of all, it allows you to copy your Blu-ray to hard drive via Mac 10.11 with original structure or main movie only. If you are running on Windows 10, simply turn to Pavtube BDMagic for Windows, which has the same function as the Mac version.
Hot Search: iTunes to NAS | Blu-ray to NAS | H.265 to NAS |
Copying Blu-rays to Synology DS416play NAS via Mac OS X El Capitan for streaming
Free Download Mac Blu-ray Ripper for Synology DS416play:
Other Download:
- Pavtube old official address: Pavtube BDMagic for Mac-rip/copy BD/DVD to Apple TV,iPad,iPhone,iPod
- Cnet Download: Pavtube BDMagic for Mac - Free download and software reviews - CNET Download.com
Step 1. Load Blu-ray Files
Insert your Blu-ray disc to the drive, then launch the Blu-ray ripping software and click the "Load Disc" button to have the Blu-ray content imported. You can also add Blu-ray discs(with BD drive), VIDEO_TS folder, Blu-ray/Blu-ray ISO files are the source files for converting.
Step 2. Select Synology DS416play NAS friendly format
Click Format bar and choose your desired format. To store hundreds of Blu-rays on NAS, you can rip Blu-ray to .mp4, or .avi, .mkv, etc compressed format. And click Settings bar, you can adjust the level of compression to suit the quality you want.
Tip: With the right settings you can retain the quality of the original Blu-ray while also saving space. This is particularly helpful when streaming over your network, depending on your network quality. Simply click Settings bar and you can tweak the settings to your satisfaction and even save it as preset.
Step 3. Start ripping Blu-ray to Synology DS416play
When everything is done, click the "Convert" button to start converting Blu-rays to Synology DS416play NAS compatible video files.
Once the conversion is finished, click "Open" to quickly find the converted movies. Then, Synology DS416play NAS will recognize, catalog, play and stream these Blu-ray rips via Mac OS X El Capitan at ease.
More
Covert H.265 Music Videos to Full ms 2008 server for Home Theater
How to Retrieve iPhone Lost Messages ?
Quora Solution Can Smart TV H6400 Play MKV?
Convert MPEG-4 to PS4 Format for Successful Playback
Extract MP3 Music from YouTube to Android/iOS Devices
Backup Blu-ray/DVD to Full MS 2008 Server for Home Theater
Best Way to Convert DVD (TV Series) to iPad Air
Rip and Convert DVD to iTunes library for syncing on Mac
Src
Backup Blu-ray to Synology DS416 NAS Via Mac OS X El Capitan
