SerenataAudio
Serenata Audio introduces its first high fidelity speaker offering; the 'Violino'.
Serenata Audio is a boutique speaker design enterprise based in Navi Mumbai focussing exclusively on high efficiency speaker systems using full range transducers.
At Serenata Audio, we believe that single driver speakers deliver a remarkable level of sonic coherence and purity of tonal textures for both vocal and instrumental music.
With single driver speakers there is no crossover circuit in the signal path between the amplifier and the speaker driver and therefore the signal driving the speaker is as pure as one can get.
Most full range drivers require reinforcement at the low frequencies and therefore the speaker enclosure assumes a pivotal role. A Back Loaded Horn enclosure effectively augments the low frequency response of the driver providing an articulate and satisfying bass presence.
The Violino is a Back Loaded Horn using the highly regarded FE126En driver from the Japanese company Fostex. Based on extensive listening sessions; we have come to the conclusion that this driver excel in the mid and high frequencies and offers a remarkable presence and imaging when it comes to vocals and acoustic instruments.
The enclosure design effectively augments the low frequency response with a gradual rolloff below 50Hz. The speaker is tuned and finished like a fine musical instrument. Solid core single strand bare copper wire with a proprietary dielectric is used for internal cabling; soldering is done using silver solder and binding posts are gold plated. Pure wool felt of a proprietary density is used for damping of the compression chamber behind the driver. The cabinet is constructed out of void free hard wood ply and finished using wood veneer hand polished with natural wax and shellac based varnish.
With a sensitivity of 93 dB/W/m; the Violino can be effectively paired with
moderately powered tube as well as solid state amplifiers having an output in the range of 10W to 15W @ 8 ohms.
Technical Specifications:
Impedance : 8 ohms
Sensitivity : 93 dB/W/m
Rated Input : 15 W
Music Power : 45 W
Frequency response : 50Hz to 25kHz
Impedance : 8 ohms
Rated Input : 15 W
Music Power : 45 W
