Should I Buy Amazon Basics Speaker Cables
The position of my speakers would mean that I'll need about 50 ft for each speaker of speaker wire. Is Amazon Basics copper speaker wire a good choice? Would be grateful for some inputs or any other decent ( not too expensive ) recommendations.
Thank you all,
I am using it for quite some time and feel they provide excellent VFM. Ideally, you should put 5/10% of your total AV budget for cables and accessories.
The position of my speakers would mean that Ill need about 50 ft for each speaker of speaker wire. Is Amazon Basics copper speaker wire a good choice? Would be grateful for some inputs or any other decent ( not too expensive ) recommendations.
Thank you all,
In a word, yes
Thank you all,
Since you're on a budget the Amazon basics cable will definitely do the job and do it fairly well.
