Sonodyne Sonus Vs Paradigm CT100
sacvaz
pune
Hi all,
I recently joined this forum. I am planning to build 5.1 home theater. I am getting confused between Sonodyne Sonus Vs Paradigm CT100.
My use will be 40% Music 40% Movies and 20% Gaming/DTH. I have auditioned both and I am inclined more towards Sonodyne Sonus. I have a friend who deals in Paradigm product and insists that it is much superior to Sonodyne (Its not because he does not have Sonodyne). Does anyone have a chance to do comparison between these 2?
I am planning to by Denon S700 W from US.
Sonodyne costs ~ 80K
Paradigm CT100 ~ 65K
Room size is 10*12 ft
I auditioned sonodyne at Melody Pro audio in Pune and Paradigm at my friend's showroom. If anyone knows who deals in these 2 brands in Pune please let me know.
Sonodyne configuration:
Sonus 2605 V3
Sonus 1501 V3
Sonus R-ears V3
Sonus C2501
You need to decide what appeals to you...hope you did the test / demo using your kind of music and movies...you need to check for easy spares / replaceable or after sales service...
The looks, performance and stability counts and so since both appeal to you...check the specs and see who is a winner...check spl levels which should be higher side...the more...the better...check which of these speaker systems perform more frequency range between 20hz - 25khz.
Thumb rule...bigger the drivers (cones of the speakers) better sound displacement for the room....all the best
Paradigm CT100 is a satellite based speaker system which suits movies... Since you have a req of 50:50 a Book Shelf speaker is better choice considering room dimension of 10 x 12 ft...
If you have already heard Sonodyne & don't find a dealer in your city, you can consider hifimart.com... I recently bought my Sonus 1501 BS from them...
Build a BS based HT system... You may consider 7.1 too :ohyeah:
Thanks efernand1 and elangoas. Sonodyne Sonus V3 if FS. I really liked the sound of Sonus over paradigm. I will search for after sales service on both the products and will decide.
