I bought the Mx binding posts in Mumbai for Rs.70/- per piece. There were few other unbranded ones for Rs.30/- per piece
All binding posts follow an international size. That is what the cup is for. You have to make a hole in the wood, or drill small holes where the binding posts go and reduce the thickness of the wood to some quarter of an inch. Try it on a wasted piece of wood, and you will know what thickness you can work with.
The binding post has to be flush outside for aesthetics and connectivity. Inside, it can very well sit inside a small well as it will not be visible to the eye.
So if we buy the binding post without a cup, we just need to drill appropriately sized round holes to insert them rather than shave off a quarter inch rectangle or square and risk the cabinet integrity... ?
I think I would prefer that any day ...
--G0bble
My problem is that most of these are quite expensive and need sourcing from US and I need quite a few, for 4 speakers and 1 spare set
I could take 10 of those if you are buying lets club them into one parcel and divide shipping by number of units.
--G0bble
clear your message box.
Are you moving these speakers frequently, or connecting them to different types of terminations? If not, you really don't need binding posts.
In fixed installations I always replace the binding posts with a barrier strip and use crimp spade lugs. They will never come loose or corrode. The connection is gas tight.
These are cheap and available everywhere.
