Speaker Suggestion for Onkyo 808
Amit21
Ahmedabad
Hi Guys,
I am in search of good speakers for Onkyo 808...all your suggestion will surely help me in deciding the same.
Presently i am having Wharf 8.4Tower, 8 Centre & 8 DFS....which are also excellent speakers, but power handling capacity is on the lower side....So i am planning to put it on sale and get new speakers for my onkyo......
808 have 230w/c @6ohm
Presently have not decided precisely on the budget but can consider spending around 50 to 60K
My Room size is around - 20 x 14...
The main issue here in Ahmedabad is that we cant get demo's of speakers most of the time ...since dealer dont stock that and they only order them back to back as per the requirement of the client....
So, all of your suggestions are very valuable...
Amit
u can try messo 8 ,it would match ur receiver and ur expectation ...............
and polk fxia6 for surrounds if ur budget suits to it
Hi Canduu
What is the current price for the same....moreover, have seen the specs of mezzo and the power handling capacity is 15-150watts .....will it match my amp specs of 230w @ 6ohm
