Speaker suggestion for Pio vsx lx 51 amp
karansfi
Hi, I want to get floor standers to match up with my existing pioneer vsx lx 51.
The room size is 23 x 14 feet.
My main preference would be clarity and sound quality at low / mid volumes. Rarely would I pump up the system and listen at loud volumes.
Budget 50k.
Please Suggest.
Budget 50k.
Please Suggest.
What are your rest of speaker? You can look at bookshelf & sub-woofer in your budget than a FS..
I'm in Noida.
I do not have any other speakers.
I don't mind looking at used speakers because I'm gonna be replacing my entire system in 2 years max.. please suggest if anyone knows a good option for used speakers in Delhi/ ncr
Here you go
https://www.olx.in/item/5-pioneer-speakers-package-for-home-theater-ID1fqVVr.html#e45f98181f
https://www.olx.in/item/audiophile-jamo-speaker-made-in-denmark-model-no-ID1fnNIL.html#d8e82e44ed
https://www.olx.in/item/original-profx-u-s-a-tower-speakers-for-sale-ID1flGwJ.html#c25dec5bfc
These are some examples...i would personally go for the ProFX ones...
Audition and decide....remember some of these sellers are dealers or even normal home users like us.....be alert and check everything.....
Thanks a lot. There are a lot of options on pro fx. Is there any particular one you are suggesting? I've tried auditioning but get very confused. Could you guys please help in terms of your experience what would be better suited with pioneer vsx lx 51? For the audition I liked the sound of a sonodyne speaker (50k) the best. A lot of people are also suggesting to go for Yamaha 8390.
Best Advice....
Take your favourite music CD or mp3 files...
Hear the same track on the different speakers....do hear Polk RTiA series towers also...
Depending on the appearance, performance and budget...shortlist and finalise...
We can advise but remember ...you are the ultimate owner and user.....it should please you...
Ok guys shortlisted these:
1. Yamaha ns 555
2. Sonodyne sonus 3165
3. Polk S55
Most of the sellers suggesting to go for ns555 because pioneer amp is low on base and I don't have a sub woofer. Also, they are not available for demo currently so I have no clue how they sound. Any thoughts??
