Speakers for Denon AVR X2300W
Go for Elac F5,B5 and center speaker for warmer sound and for brighter go for Dali Zenser 7 or 5, 1 and Vokal.
Sent from my Le X507 using Tapatalk
Hello Friends,
Bought Denon X2300W and now in market for 5.1 speakers.
Movies 80%, Music 20%.
Room Size : 11x20 ft
Congrats..
Don't think 50 feet cable will do for you.. You might need 100ft roll..Amazon.in: Buy AmazonBasics 14-Gauge Speaker wire - 100 feet Online at Low Prices in India | AmazonBasics Reviews & Ratings
Please suggest speakers
80% movies and a longish room, you can consider satellite speakers and dual subs..(if your budget permits)
Hello Friends,
Please suggest speakers and cables ?
Congratulations on getting the receiver. Have you auditioned any speakers yet? What did you audition the Denon with?
If there is a Pro Fx outlet in your place, you should visit it and audition the Polk Audio offerings. Their Rti series is quite good, matches well with Denon and is known to suit movies more than music, however, that can be debated.
Another good option would be Dali Zensor series, which are also very good and suit both Movies and Music equally well.
Other options would be from Q Acoustics, PSB, etc.
Audition is the key. Our tastes could be different from yours. You could Audition, shortlist and then take it forward by discussing them here.
I am on the look out too to get front speakers and have my eyes on the Dali Zensor 3. They are not easily available in the Pre Used market, which excites me. So exploring other options, if not, will go buy a new pair of Zensor 3.
Happy Hunting
MaSh
@ diliplp
what is the budget set for speakers? Have you auditioned any so far? Remember to carry your favorite music / movie scene and audition the same content on different speaker sets which will help in deciding....
Happy Hunting
MaSh
Thanks. With very limited HIFI stores and models, audition is very difficult in my city, i.e. Vadodara, Gujarat.
Got AVR from UK, based on reviews only, never heard it. Yeah I know, but it wasn't possible for me.
I can carry AVR and ask for demo on it if they allow, will check once I receive AVR.
Zensor will be out of my budget mostly, I can try to import when possible.
@ diliplp
Budget is 35-45k if getting complete set in one shot, can't spend much right now, I have edifier DA5000 Pro 5.1 speakers, so I can upgrade gradually as suggested many times over this forum.
How about TAGA 606v3?
I am open to used items also and checking sale section regularly.
Thanks for your inputs.
Check out profx online, given them a call to see if they deliver to your town. Check out olx too, many dealers post their stuff online. However, you won't get any warranty on such items.
You could start with getting a pair of front speakers and then upgrade the rest in stages. Or check Polk TL1600, nice unit for a small to medium size room. http://www.profx.com/detailpage?bra...16&Id_detail=108&aclass=2&menu=1&calledFrom=0
MaSh
Sent from my Redmi Note 3
Tannoy speakers will sound great
Ok, will check them.
Go for Elac F5 said:
OK, I like brighter sound, will check them.
Congrats..
Though its long room, I am putting my setup in left half of the room, TV on the long wall. Dual sub is financially difficult, lets c.
One again thanks all friends for your valuable inputs.
Hello Friends,
Cables : Amazon.in: Buy AmazonBasics 14-Gauge Speaker wire - 50 feet Online at Low Prices in India | AmazonBasics Reviews & Ratings
How's this cable ?
For Denon AVR-X2300W, my choice would be to go with Wharfedale Diamond 230/240C Series Towers.
Or of you don't want Wharfedales, you can go for JBL Studio 280 Series towers. They are a bit costly, but worth it.
You can later pair them with the same brand Center, Surround and a Subwoofer for a better match.
I have denon avr 1200w with q acoustics tower and 5.1 speakers, and blown away by the performance. Check the q acoustic 3000 series.
Sent from my H60-L04 using Tapatalk
If you are on tight budget then I will suggest you go for JBL Cinema 610 . Initially use it in 5.1 mode afterwards upgrade with good floor standingas speaker and use in 5.1.
2 mode. Afterwards you can upgrade surround , Atmos and Subwoofer as required. Till then you can enjoy full 5.1 surround sound of movies.
AVR is yet to be delivered and one more friend is coming who is willing to bring speakers ( fronts and center only, may be rear too if possible ) :)
Fronts n Center : Shorlisted Dali Zensor 1@150GBP as fronts with Dali Pico Vokal, pico being smaller, will match with zensor 1 ?
getting Pico Voakl @79GBP while Zensal Vokal costing 229GBP, is it worth the big difference ? on tight budget here. Other options if they match https://www.richersounds.com/products/hi-fi-separates/speakers/centre-speakers
Rear : I can get zensor 1 as rear too, also getting mission LX 2, Q3010 all around same price range.
Please suggest, need to order ASAP.
I am open to any other brands/models, budget is approx 200GBP for fronts, 100 for center and 150 for rear. not importing sub for now.
