Speakers With Norge 2060
vardesh
mumbai
Hi All,
I am looking for Bookshelf Speakers to connect with Norge 2060.As per post's on forum Norge MK2 and Wharf 9.2 are better match.I would have gone with 9.2 but it it out of shelf now.Anyone using bookshelf either than above two makes please provide details.
I require quite good bass and looking below 20k.
Does Polk tsi200 matches well with amp 2060 ,any review.
Thx,
Vardesh
Hi Vardesh,
Try MS Aviano-2 at that price, you will be rewarded, but the weakest link will be the internal pre-amp of Norge.
N.Murali
Go to Norge Factory @ Mahim & listen to the New Millenium MKII & Ultimo BS Speakers
Norge Audio
Norge Audio
Thank You for reply denom.
I have used Norge Bookshelf ,I want to go with other brands which can be less than 20k and used by FM with Norge 2060 with good result.
I think the Boston A26 @ less than 19k (@Hifimart) may be given a try. Has had good reviews.
N.Murali
Try Nibbana Audio Fire-starters
price 15 K,
or Monitor audio Bronze BX2 not sure abt price..
I have Heco victa 301 paired with Norge 1000 Gold. Which sounds impressive...
Thank You All for reply.
Really appreciate all of you for replies.
Good options to check, will surely look for something among them.
Vardesh
Hi Vardesh,
I have paired the Norge with Monitor Audio M2. Excellent results! They are priced at 14 k
I have owned the tsi 300 with Norge 2060 and would suggest other options for music listening. I used the tsi for ht and got the wharfs 9.1 which were much more musical. But yes audition and decide.
Vardesh,
Once I called Mr bajaj ( Norge Owner) for this . He said ,for Polk speakers he recommends Norge 1000 Gold over 2060 as Polks are more power hungry.
He suggested to use 6 ohm speakers for 2060.
My suggestion - Try
- Magnat Supreme 200 - Rs 14200 (Have audition first)
- PSB image B15 -- ~ RS 20K (it has good reviews all over)
