Suggestion for Stereo set up
ram122
Suggestion for Stereo set up !!!
" Made in India" Stereo amplifiers and Speakers for a room ~ 225 sqft budget is not too high 20K excluding the input ( CD player etc).
Music : Instrumental, hip hop
Either go for AE5.
Or Norge 2060 + Wharf 9.1 + an ordinary DVD player
either way you will shell out close to 20k
norge + wharf is a good combo.. however you wud need to spend for stands for BS
if you can shell out more..
then norge+ telome bt 300.. they will also do a good job...
Re: Suggestion for Stereo set up !!!
Hi ram,
Considering your above factors I suggest following options:
1. Norge-2060 @7.5k + Norge Millenium @12k + regular LG DVD Player @2.5k = 22k
2. Norge-2060 @7.5k + Wharfe 9.2 @14.5k + regular LG DVD Player @2.5k = 24.5k
BTW reg AE5 suggestion by Techboy in this thread, I don't think they can deliver the type and quantity of bass required for hip hop. Even 9.1 woudln't do for hip hop. Ram, You should audition these personally, before taking decision.
Regds,
Sonosphere
It will be a tough call btw the Whafs and the AE5.
Bass/Laid back sound: Wharf
Neutral/Balanced sound: AE5
So it depends on you.
ram look for a used norge amp .. along with wharf as they are the most recommended ones here...
that will fit your budget
