The DLS Faltbox!!
Decibel
Chennai
The DLS Flatbox for in- or on-wall installation!!
[IMG2]http://img594.imageshack.us/img594/2252/dlsflatbox1.jpg[/IMG2]The Flatbox from DLS come in 5 convenient sizes to set up a 5.1 or a 7.1. All of these speakers can be mounted as in-wall speakers or simplly hung on the wall as on-wall speakers, either horizontally or vertically. The speakers are bass reflex and come with three drivers each. They are capable of handing a frequency range of 70-25KHz, while the sub can go down to 35Hz. With a depth of just 3.62 inches, the Faltbox fits very well into room aesthetics while delivering the much needed visceral experience. 'Consider this system if you want a speaker setup with quality sonic performance and a solid price to performance ratio', says AV Max. 'Partnered with Resolution Audios Opus 21 system and inexpensive DNM cables, the speakers threw a surprisingly wide stage, despite being mounted on temporary plywood walls.' says Stereophile.
You can configure a complete 5.1 for between 80-90K.
