Folks, I recently had to open up the speaker-cabinets (if I may call them that) of my old Sony boombox to replace the blown mid-bass drivers. What I found inside really surprised me - the drivers were really puny! Anyway, let me lay out the story in proper sequence.
I have this old Sony CFD 550 "boom box" which I had bought more than 20 years ago while in the US.
This is how it looks (photo from the net)
It had been lying around unused (the tape belts are broken and the CD lens does not work anymore) and a few weeks back, I decided to use the speakers from this setup with my NAD C350 amp which was lying around, as my computer audio setup. I was not looking for great sound, just some background music while I worked. So, I connected the speakers to my NAD, and used a Centrance Dacport to connect my laptop to the amp.
I had just started enjoying the music and tried cranking the volume up a bit, when suddenly, the speakers went silent. Or rather, only the small tweeters could be heard, but not the mid-bass drivers. I guessed I had blown the drivers. I had known this could happen because I was sure the speakers were not designed to handle the 50W+ that the NAD could put out. OK, time to replace the drivers.
So I brought out the heavy artillery...
And started opening up the speakers boxes....
Now, this is how the boxes look close-up. Note the "Megabass" branding...
And then, on opening up the rear-panel and exposing the drivers - what a shock!
A 2.5 W driver !! What was Sony thinking? A "Megabass" "boom box" with a 2.5 W driver? I had no words... No wonder my NAD had killed the drivers on both channels! And note that these were 3.5 ohms, meaning the output would have been higher.
And no cross-overs either! This setup is worse than some of the old transistor-radios I had opened up back in the days.
And look at the cone, how do you expect any bass, forget "megabass" out of this cone?
Anyways, time to replace these, what do I use? Remember, I just wanted some decent music, so instead of going for some expensive drivers, I decided to use cheap car stereo components.
Went out and got these
The packaging claims these go up to 190W! I am sure that is a little overboard, but with these, I am reasonably safe, as I do not intend to go to loud in this setup.
Here is how the driver looks after opening the package - 30W nominal, 4 ohms, good enough..
And here is how the speakers look after the install..
And then, I set up the ASIO4all driver on foobar2000 to start enjoying bit-perfect sound through the system. The drivers are not great, obviously. The bass is not much better. But it is good enough for my background listening needs.
