this thread is probably a bit premature as i still have a few pending projects and it will take a few months before i can get to it, still want to start atleast the research. I am looking to get something tubey just to get some exposure. I have heard tube setups here and there for very short durations only.
Few key requirements:
1. diy only. dont want to spend a bomb on this. No expensive tubes please. PCB will be good, but dont mind doing p2p if the ckt is simple. Will probably use some kind of perf board in that case.
2. low voltage only. Is there an inherent disadvantage in going with low voltage tubes. Dont want to deal with high voltages or output transformers.
3. buffer/hp amp only. no power amps at this stage. hp amp should not be very restricted in terms of what impedance loads it can drive. Aikido and heretical look like two good candidates for buffers.
4. Dont want sugar coated stuff. just looking to add a bit of warmth and take away some harshness. BTW, is 'sugar coatedness' a property of the design or the tube itself.
All of you tube gurus, how did you start your tube journey.
