I recently bought the Wharfedale SW150. The Auto Power button is set to ON, which is the recommended setting and my preference. However, after some duration of non-usage, the sub woofer does not turn itself ON again when signal is fed to it, either from DVD or TV set top box through AV receiver. I have to reach to the rear bottom of the box to manually switch OFF power and then switch ON for the system to kick in. Receiver is Onkyo TX SR 5 series.
I spoke to the dealer. He did not seem to get what I was saying. However he added that if there is a technical problem, he will have to check it and if necessary send it to Mumbai for repair. Will they be able to really repair it? I mean, most speaker dealers are just import-and-sell set ups, AFAIK. Should I give it for repair? Should I demand replacement? Or am I missing some settings?
