Yamaha rx-v671 or marantaz nr1402
janarthanan n
coimbatore
Hi friends
i am having a doubt
1.my room size is 10*14
2.i like music 80% watch movie only 20%
3now i am using philips 7.1 analog output bd player +8 ohms 15w 5.1 juster (taiwan made) speakers sub 45w
4. Now i want to upgrade my home theater setup
my budget avr=upto 25000
which avr is suitable for my speakers (yamaha rx-v671 or marantz nr1402)
basicly i wont like heavy base
kindly give sugession
jana
You won't get Yamaha 671 for 25K. Other models to look for are Yamaha 371 and Denon 1312. Yamaha 371 is available in ebay for 18K with bill and warranty.
yamaha 371 is available at Reliance Digital for 20k last week. Hence AV stores should be selling it for less.
1. the sound signature depends on speakers and amp/AVR. Further, music or movies ... the speakers play a major role and not just AVR.
2. If it is mostly music I would recommend stereo + good speakers than AVR + existing speakers.
3. For the 25k budget I would suggest you to try a resale stereo amp around 10k. Park 15k and save more to it and buy a good pair of speakers.
If you have decided to buy only AVR, I strongly suggest you to audition it with your speakers.
tnx for ur reply
I LIKE HEARING THE MUSIC IN 5.1 ONLY.SO STEREO AMP IS ADVISABLE OR NOT
MY IDEA
IN FUTURE ALL ARE IN NETWORK ONLY. SO YAMAHA RX-671 IS BETTER OR NOT
KINDLY REPLY
