john_k_antony
Friends,
I would like to get your valuable recommendation for the AC for my dedicated HT room.
My house is in Bangalore and its a duplex house. HT room is on the 1st floor with a flat roof. 2 sides of the room is exposed to sun light. There are no windows for the room. Wire cut red bricks are used for construction. The room dimensions are 24x15.7x10. After acoustic treatment, I hope the dimensions to change to 24x15x9 making the volume of the room to be 3250 cuft.
Now comes the challenging part. Which options to choose from below for AC in the room?
1. Type - Split / Cassette
2. Capacity - 2/3/4 T
3. Operation Type - Inverter / Regular
4. Budget - 1L (including installation)
5. Any specific brand recommendation ?
Thank you very much in advance for your valuable inputs.
Thanks,
John.
Thanks,
John.
