advice on 50 inch Samsung Plasma
uziel
New Delhi
Hello, I am finallizing on 50c450 and 50c550. Just need some expert advice as to apart from Full HD, why should I spend extra money of 550 series than 450 series. some answers that i am looking for
(a) Does DLNA pratically work specially with B/G Routers
(b) Any alternative in 50 incher under same budget of 65K
(c) At this age, will buying Plasmas will be a total crime or its sustainable?:sad:
my 2 cents
Go for Full HD to be future proof.
No idea about DLNA since I use Xtreamer and am very happy.
Also you can go for LG 50PK550R. I own one and Am happy
This is the Quote I got for my friend yesterday.
62000 ( Includes a 320 GB 2.5' External Disk and Tatasky (not HD) )
0% EMI and 1/3 is down payment.
Jatin
In both Respects (PQ and Feature) Samsung is Better than LG in my Opinion.
But I would suggest to go for LG and a HD media Player (Any) separately as it will be better VFM. The difference in LG and Samsung is close to 10 K and you can purchase a HD player in that Amount that will have more features than the Samsung Built in Playing capabilities.
If you plan to keep this TV for more than a year - don't go for a cheaper model just so you can save a few thousands. You will regret it.
