I have putup some actual pictures of Samsung Plasma 50 inch Full HD TV PS50C550G1R as in India quite different from whats given in other countries. Immediate notice was there was no lighting in the remote unit. This TV unit dated October 2010. The package is quite slim but the length is a bit on the higher side. The original package contains the stand, TV, mounting kit, documentation, remote and the power cable. The wall mounting can be done by samsung engineers anytime till a year from the date of purchase. I am putting some initial observation from my side, may be irrelevant but thought to document it. (will add later as time passes)
Some Pros: :clapping:
(a) The TV Body built looks quite solid
(b) Ports are adequate and well placed
(c) The front right lower panel is almost touch operation of panel buttons
(d) No Buzzing and acceptabable heat dessipation
(e) Best VFM when source is full HD
(f) Screen Swivel 20 degree each side.
Some Cons: :sad:
(a) Date & time has to be reset everytime you hard power up/down.
(b) While playinng from USB, many issues regards format acceptance
(c) While playing over Network, fastforward/reverse does not work
(d) Allshare has lotza limitations
(e) Regards DLNA, Samsung PC Share manager has limited capability. I had to use Mezzmo which is much more capable
(f) Support staff at Samsung have limited knowledge of DLNA & allshare
(g) No wireless dongle supplied.
Some Cons: :sad:
