Audiodoc
The three legged cabinet will be stable as long as the toroid is mounted in the centre. This limits the various configurations that mishraji may have planned of isolating the power supply to a corner.
hyeah: I am planning MyRef from LinuxGuru. The kit and toroid is waiting here since a year now. All part are on the table. Now thinking different strategies.
4 legs will HAVE to be levelled
p.S amp will also be stable if toroid is loaded on front corners ( doesnt have to be in the centre ) - just not in the rear corners
OM : your volume knob is still with me
about the extra long scews
im pretty sure that 4 nos were included inside the pass labs cab
were they not there? - the allen key type ones ?
you can use them on the front plate at least
Yeah there are 4 longer screws available bit I thought they are given for fixing the volume and selector knobs aren't they. If not, how do we fix the volume knobs?
BTW, what about the exchange of knobs?
I got 2 knobs, one beveled and one plain. Prefer both plain.
threading was NEVER done on the side panel
the screws made their own threads as i screwed them in
the side panel is meant for self tapping screws
and this was the reason i kept saying in my mails and posts- DONT detatch the panels AS far as possible
the allen key is hardened steel
please go ahead and tighten
wood panels are far more costly than the aluminium extrsuions
they require sanding
then polish
then melamine
and lastly fitting in the inserts
whats more
the wood panels wont work in the B1 cab
the wood panels are 19mm thick
they will eat into the space of the baseplate- the core, PS supply , phonostage PCBs wont fit
Not only that since i dont have the front and rear plates now - allignemnt issues will be serious
knobs
im sorry
you guys will have to cross maill yourselves if you do not like the combination
or capt mail me the beveled knob back
ill add a knob in your power amp
same dimsns only NO bevel
i dont have knobs in stock currently
but may produce a couple next week
Magma,
Symmetry seems to have gone awry....
Cheers.
I did not mean between two monoblocs. The monobloc is not symmetrical with two big heatsinks struck on the front side and huge step after that for the cabinet.
My view is that one heatsink on either side of the cabinet would make more evenly dimensioned cabinet.
The other option is, you could have just raised the cabinet height to suit the heatsink height or cut the heatsink to the cabinet height which ever way.
The shape in current form looks quite odd. My two cents.
Cheers.
ahhh ok now i get what you mean
hmm the cabinets are custom made for the raksang rack
once they are loaded onto the rack they will fit it- thats where the overhang will make sense
maybe the buyer will post his pics loaded onto the rack later
