just4kix
Check in "Advance Settings".
Ohh, 24p Smooth Film is Intelligent Frame Creation on my set, I think and it's turned off.
Do you see very clear picture like you see on LCD / LED or it's bit grainy ? I see grains when I come near say, 1 ft. Is it supposed to be grainy ? The texts are affected too when I'm using with PC.
I saw some Image Retention yesterday. I was browsing and when I turned off the TV, I can see the bar on the top side of the TV. The "info" which comes when turning the TV on and off for few seconds also appeared. Turned off the TV and I can see the IR in the dark. Then within few mins, everything is normal. Is this normal or I should start the break-in ?
Well, I thought that it might be a good deal if I can get the TV for 41-42K with 4 3D glasses and 3 years warranty. Do you think I should return this TV and get a LED instead ?
I talked to the sales-person just now and he's saying that they don't have any more XT50 in stock as Panasonic is not sending them any. Talked to Panasonic India and they confirmed that they're not supplying XT50 anymore as they're releasing new models this year. The sales-person told me that I can get LG or Samsung plasma if I want (as replacement) but he want me to stick to Panasonic as their panel is premium.
I checked the Samsung F4900 at store and it was missing something, don't know what. Although, I might give it a try too. But after that, I can't get back to anything
