Best ever deal for loudspeaker kits.
Dear Forum Members,
I just had a tele conversation with the Captain, who told me about this group buy and asked me whether I know someone who could make cabinets. I guess that happened when we were talking of my 8' tall LINE ARRAY PROJECT. As a matter of fact, I am getting my line array (visit True Audio: Audio Spectrum Analyzer and Loudspeaker Design Software or google 'murphy corner line array' AND 'jim griffin's white paper on line array' to know more) from FM Kanwar's woodcraft facility for Pro Audio enclosures. The pics vide this link give us SOME idea of the craftsmanship and professionalism involved.
Pro-Audio pics
Now, I have spoken to Kanwar and although this isnt his bread and butter, he has kindly consented to undertake the bulk-order GROUP-BUILD project for HFV members as a special gesture. The final pricing will of course depend on the choice of material
[eg Baltic/Russian BIRCH ply or Marine-grade(waterproof) ply or just plain good old MDF]
and of course, the intricacy of the speaker construction plan(s).
I have seen and heard stuff made by Kanwar's Zypher Power Labs and I can vouch for two things ie COMPETITIVE PRICING and Quality of CRAFTSMANSHIP in construction.
Sadly, I have grown out of 2 way speakers with passive XOs and as is the case with me, I choose to tread the path less chosen with line-arrays, open baffles/dipoles, constant directivity & horns and a 21 inch sealed sub being more of my kind of thing. That, my friends is the only reason that I am constrained so as to not subscribe to this wonderful group BUY n BUILD. In fact, I will be selling all three pairs of speakers and two subwoofers(one is passive) that I currently own after/before the projects take shape. These are 2xlithos Q10, 2xlithos noa1, 2xmission m34i, 1xlithos Q-bic sub and 1xlithos Noa1 passive sub. Yes, someone is going to get very lucky as all my eqpt is the way it came and I shall be selling it because of need of money and lack of space.
Therefore, I have no commercial interests, whatsoever, in posting this save the desire that fellow forum members get MORE FOR LESS by all contemporary standards.
As per the Captain's directions, I have already sent the u/m bulk order estimate for Kanwar and his Chief craftsman to work out expenses:-
(It may please be kept in mind that Kanwar's wood-working lines do NOT presently cater for the external veneer/polished finish desirable in home-audio, hence the same will have to be out-sourced, which is likely to push the costs up marginally, but it is still going to be a SUITABLE COST. Those of you who have been following my posts may know that I am one hell of a stickler for value for money)
14 x prs front xls encore
5 x center ch matching
5 x surround av1(?)
4 x subwoofer 12B(incl 1 double dvr sub)
2 x single dvr servo sub
1 x double dvr servo sub.
I hereby request and suggest more FMs to avail of this golden opportunity as the MORE THE MERRIER (CHEAPER TOO). This kind of an opportunity does not come everyday and I have half a mind to go I for it myself but then my head (just this once) gets the better of my poor heart. However, I shall see if I can rope in some/any non-member friends.
Meanwhile, I shall request the Captain to take the lead and:-
(a) Consolidate/amend/update the final demand piece-wise.
(b) Arrive at a consensus for choice of material and other parameters.
(c) Provide speaker construction plans at the earliest. No plan, no estimate, you see.
(Kanwar recommends MDF for smaller budget conscious enclosure and Baltic/Russian Birch ply or Marine (waterproof) ply for larger ones. Obviously, top grade birch ply is about 4 times the cost of MDF, with marine-grade falling mid-way, costwise.)
All other forum members are requested in their own interest, to give this wide publicity so that costs come further down.
Last but far from least, I request Kanwar to take some time out to visit this thread and be available to answer any possible queries. I personally feel that shipping of so many drivers back and forth will add to the costs so depending on what Kanwar says, I suggest its better to have all the drivers delivered wherever the cabinets are to be made.
Over to you, Captain and Kanwar.
Warmest Regards, All.
Because the X-CS uses a higher order crossover on the tweeter (more caps). So the Sonicap upgrade for a single speaker is $67.15 and Mills resistors are $9.80
That puts them right up there with the A/V-3S using the same parts and even edged it out in the high frequency range with that Peerless Tweeter.
What about Erse Inductor? Is it not required for the centre channel?
Hi Danny,
you have mentioned that sonicaps is the value upgrade. So what would be the difference between just sonicaps and the full monty in terms of performance?
If we want to upgrade later, is it as simple as buying the components from you, removing the old components and soldering the new ones at the correct places? Would there be a cost difference if we chose this way?
Hi Danny,
The biggest upgrade is going to the Sonicaps. Clarity, resolution levels, everything is up a notch. The Mills resistor upgrade is noticeable but not huge.
You can upgrade them any time. If you later decide you want the caps to upgrade them then it won't cost much to put a handful of capacitors in the mail to you.
And yes, it is as simple as removing the old caps from the board, and soldering in the new ones in their place.
I am thinking about upgrading the fronts to statik and voce to get the "open" sound, and these are more efficient i can probably drive with linux guru's myref amps
http://www.avsforum.com/avs-vb/showthread.php?t=1081293
http://www.audiocircle.com/index.php?topic=61602.0
http://www.stereomojo.com/RMAF 2008/RMAF2008BESTOFSHOW.htm
Also need to spend a 7.2k(from magma for the alif) for the bookshelf stands if i go for encores, so not much increase in cost in comparison
Danny said they need to be 3ft away only from rear wall and sidewall distance is not important( like omnis which need to be 3ft from any wall)
yes, i agree, would be easier and cheaper from there to bring it to bangalore
Captain,
This thread has become very large ...Why dont you open a new thread where
1) list of participants in the GB will be there. New members will keep getting added ..
2) Any discussions reg cabinets / logistics / any queries etc
Since Danny is sending the kits with advice from Peerless guys, I think Mumbai will be a good idea as the Peerless guys would be well versed with the working of Mumbai port.
This is only if Peerless is ready to provide some help in clearing the goods.
But again one of the buyers from Mumbai will have to take the responsibility to send the kits to other parts of India
@stereorules how does it matter how big the thread is? IMHO a a participant sh get all the info so that if makes an informed decision. @rikhav I thought about it. The kits are apparently cmg from US & I'm not sure if peerless would take ur the responsibility. Will wait to what Danny has to say no this.
Am not talking about Peerless taking any responsibilities. Infact its not their job also
But if Danny can talk to someone close in peerless, they can give some advice as they will know how the system works in mumbai very well and maybe share their clearing agent.
