Bluetooth interruption in Denon X3200
goenkakushal
Helloo experts...
I have discovered a strange problem in my Denon X3200 (USA model)
Denon works fine on bluetooth mode with any mobile when I use it without switching ON the TV.
However, when I play the same when TV is ON the problem starts.. The audio gets interrupted as if the Mobile is out of bluetooth range.
Following Troubleshooting already tried
1. Used different Mobile to play music and different music app as well but did not help
2. Tried to play music from the same distance from which I usually use and it works perfectly when TV is OFF (just to be sure its in range) this too didnt help
3. Now I tried to keep the mobile adjacent to the AVR.. This trick worked
Now the problem is that obviously I cant always use the Bluetooth keeping my phone adjacent to AVR .
TV is connected to my Denon via ARC port and displays the song being played properly , also there is no issue when I play any other audio from the TV itself.
Question to be answered --->
How can switching on TV reduce my AVR's Bluetooth range?
How can this be overcome ?
Is this Hardware issue or Software issue?
Are any of you facing similar issue ?
Kushal Goenka
