Cambridge audio sr20 : Seeking reviews
Kumar442244
Hello FMs,
Tried looking out in this forum but couldn't find many reviews about this amp.
Could anyone share his experience of possession/audition of this amp?
Could this be a good buy in <40K budget or something else?
It's 100 WPC with Wolfson DAC and lot of connectivity options.
Also, which speaker could be the best match.
This is for one of my friends.
Choice of music is Rock, Pop, ghazals and old new Hindi songs and source will be laptop/ mobile/USB devices.
Kindly advise.
Consider this, if it interests you.. Shouldn't cost more than 12K, inclusive of importing it to India..
https://www.aliexpress.com/item/FX-...817979852.html?spm=2114.search0104.0.0.vdP1PD
- This amp has USB input & Micro SD card.. Supports most common formats (MP3, FLAC, WAV)
- This can be connected to Laptop thru USB input..
- Has bluetooth connectivity for mobile..
- Also has sub out..
- Ample power
You can spend the remaining budget on speakers of his choice..
Thanks, Elangoas for the response.And apologies for the late reply.
Not quite sure if I would be taking that route Elangoas.
COuld not find any review for SR20 on net/this forum.
Anyone who has used this amp?
Kumar - did you end up buying the CA sr20? Can you please share your review?
Hello naren,
This one was for one if my friends. Ultimately, he ended up buying nad, the Same amp which I am using. Nad c326bee.
Are u on a look out for an amp?
