decoupling my dick smith floorstanders !
May be you can think of using concrete paver blocks. It may be possible to speak to the paver block manufacturer and he may keep holes as per your direction when the blocks are being made. Just a wild guess. Don't know whether they can/will do it for just 2 pieces but there should be some way.
ive made my decision lol >>>>>GRANITE ALL THE WAY <<<<<
Thats a solid decision !! :clapping: find one thicker than 19mm is a challenge though.
Do try the blu-tack method for 100 rupees before you try the cone solution for 800 ...
--G0bble
This thread just came up in time when I was looking at DIY methods of increasing the height of the floor stander. My better half decided to have a go at picking up new furniture and ended up buying a new couch. I used to have a 3+2 corner seater earlier and had good 12 feet or so between the seating area and the HT/TV. She rid the old one and picked up a new 3+1+1 couch 2 days back.
Went home last evening after work and was in for a shock. The listening experience itself is completely messed up. With the single seaters put opposite to each other, the distance between the couch(single seaters) and the FS have reduced to about 4/5 feet and the darn couches arm rests are pretty much blocking the sound from the FS.
Got 3 books , stacked them up and put the FS on them and viola I had what I was looking for. Obviously cannot touch the couch or think anything on the lines of even moving it around.
Now on calculation I found that I need to raise the FS by 4/5 inches at-least to get back to where it was.
Am toying the idea given by magma. Wood base with spikes and them granite atop the wood.Obviously finding granite at that size is gonna be tough and I would have stack them upon one another. Drilling the granite for spikes is another fiasco by itself.
So does the order spikes --> solid wood--> granite --> FS make sense at all or solid wood and granite be interchanged ?
if you like i can do the wood and spike work (if you dont fancy DIY)
all you will then have to do is get a marble or granite pc and affix it on the top
Will you be able to send me the spikes if I give you the measurements pal ?
Guess magma can send you spikes --> solid wood--> granite -- package. As I see he has custom options on his website. :D
just my two paisa..... better to go for a thicker granite or double granite stuck together than a wood-granite composite structure!
To OP:
Can you please either remove "my" from the title of the thread or at least change the speaker name to capital like "Dick Smith"? It's very distracting. :P ;)
To OP:
:confused::confused::confused::confused:
they're MY speakers....what's "very distracting" if i've personalized the post title!
I never told any sexual comment, you yourself is highlighting it in this post...:lol::lol::lol:
yea because i was born this morning and the sun shines at night! happy????
got over your 5 mins of cheap thrills!
:lol:, Buddy dont take these kind of harmless jokes seriously....move on...:lol:
sure BUDDY ....!
i've moved on since yesterday..but every time i move on....someone pops up like a multi-headed hydra and starts these innuendos all over again literally begging to be attended to....
Forget it Sean. Its all in the name. Next time you start thread about your speakers, don't mention the name in title, just write 'floor standers' and people will not have the urge to say something about the Name.
I can't edit or remove the 'inappropriate' comment I posted. Sorry if my comments hurt your feelings.
