eummagic
Hi all,
Iam planning to construct a new house and also making my dream real by building a dedicated home theatre room in Cochin, Kerala.
I had earlier started a thread regarding anamorphic lens with 2.35:1 aspect ratio. During the process, I am able to short list Panasonic PT-AE4000 for its features & performance like anamorphic emulation, lens memory function, excellent color reproduction out of the box (if calibrated reference color) as per reviews floating in the net and yet not able to see a demo of the same. But, I have seen the demo of PT-AE2000 in Chennai 1 1/2 yrs back and impressed.
Now, here in Cochin I have contacted a local home theatre consultant from "Lal Media Arts" who are into film production, distribution and home theatre equipment seller and acoustic consultants. Some of the points are highlighted below from the discussion with this consultant.
1) Regarding my space for construction of my new house I have told the consultant that I can have a dedicated room of 11ft (wide) x 14ft(length) x 10ft (height). He suggested to have 12 ft (wide) & 16ft (length) if possible and if the room height can be 12ft (height) since when doing acoustics he will need 2ft so ultimately the room would be 10ft after completion.
2) The screen 103" (2.35:1) as planned by me is possible. He told ideally the screen should start 3 to 3 1/2ft from the floor. So, that was the reason of having a 12ft (height) which will give the right visualisation and spacing.
As per calculation:
Room height: 12ft
Acoustic treatment space from ceiling: 2ft
Screen height (incl frame) : 3.88ft
From floor to screen: 3.6ft
Balance free space: 2.52ft
3) For flooring he suggested for wooden flooring instead of carpeting, because this room would be the ideal entertainment room for all including kids. So, there is always a chance of minute dust collecting even though it is cleaned regularly. So, this can cause allergy/health issue to kids.
4) Regarding the side wall acoustic material he told that he wouldn't use Gypsum boards again due to health/allergy reasons and would use a similar material known as pebble (felt like thick thermocol but not breakable).
5) For cabling, he told that he would not compromise on quality and he is mostly using Chord cable for speakers/av connectors which gives more life span.
6) As for seating, he told that we can have a one row seat where 3 or 4 people can sit comfortably at the back and then have diwan like arrangement in the middle or using bean bag.
7) As for equipment rack it can be placed on the rear above 4 or 5 feet from the floor. So that the HDMI cable length can be well within the reach of the projector instead of going for 10mt/15mt cabling.
8) According to his suggestion, windows is not required but since this is a home theatre and not professional studio you can have atleast 1 on either side of the walls as shown below.
OUTSIDE
INSIDE ROOM
W=Window, opeining outside. Can have dark colored glass for windows and also dark curtains between the inner wall gap.
9) He is totally against LCD projectors and he was suggesting me DLP.
Can you pls give your comments made by the consultant...
As per calculation:
Room height: 12ft
OUTSIDE
INSIDE ROOM
