Denon Avr 1910 +Jamo A102 (Excluding Front Spekars)+Warfdale 9.2 front Speakers
deven_shah
Hi All
I am planning for Denon Avr 1910 + Jamo A102 (Excluding Front Spekars) + Warfdale 9.2 only front Speaker.
Reason i am opting for Warfdale 9.2 Front speakers is purely for music.
My choice would be 60% Music & 30% movies.
I got Demo for Jamo A102 on marantz (eZone, Oberoi Mall, Goregoan, Mumbai) and was preety good. Not sure how will they perform on Denon 1910.
Jamo A102 are preety small & cute speakers.
Let me know your views on this setup or any other better setup.
Deven
Please make a note that whatever setup you buy for fronts, then the Left, Center and Right should be from the same series/Brand. So in this case if you are planning to go with Wharfedale 9.2 for fronts then get the matching center too from the same series or else go for the complete Jamo A102 setup and buy Wharfedales seperately and hook them onto the speaker B terminal of your Denon and use them for your Music listining and use the Jamo setup for the Movies.
Hi!! Ashish
Thx!! for your suggestion i was not aware of it . Any idea how will wharfedale 9.2 perform on Denon 1910.
Deven
