Vivek Batra
Hi @MianyI can share more details once i have completed everything.
How is your coming up? Any updates/pics?
I guess I know this member. Will try to find the thread.I am unable to find this thread. Just have the pics. Had saved them. Maybe someone can remember the thread.
View attachment 61326View attachment 61327View attachment 61328
Wow! Super cool room. Wonder what’s with the textured pyramid/triangles in the centre?I am unable to find this thread. Just have the pics. Had saved them. Maybe someone can remember the thread.
Nice! A truly beautiful dedicated room for audio.I am unable to find this thread. Just have the pics. Had saved them. Maybe someone can remember the thread.
What speakers are these buddy?I am unable to find this thread. Just have the pics. Had saved them. Maybe someone can remember the thread.
No idea.What speakers are these buddy?
Vivek Batra,Hi @Indranil Sen
Thanks for your detailed and informative reply. I am noting down each every suggestion shared here by all of you and it's coming up nicely.
Few things that are already prioritised for the room
1. LAN cable
2. UPS/Stabilizer outside the room
3. Dedicated phase and line with proper grounding. Just a dedicated line is not helping properly right now.
4. Avoid having the door in the corner, if layout allows.
5. International sockets, AV grade
6. Yellow lighting with dimmers.
7. Conduits to hide cables while running from amps to speakers or where required
8. Ample rectangular room size may be 20x15 feet.
9. Room treatment at later stage.
10. May be fixed furniture to hold all av equipment. Not sure if I should still buy a rack.
I guess this list will keep on refining as the plan progress. Once the layout is I will share the room dimensions again if that's a good space I can move on with the construction.
Vivek
Most probably, I am gonna install a solar power system and will see if its possible to have a dedicated line from the plant directly.dedicated power line from home main distribution board, totally separate from entire house supply. Use high quality copper shielded cable.
I guess if the source is solar power, the chances of surge are very less?Add surge protection on this power line, and Also to make sure it's high quality and reliable.
I am also thinking of not having the equipment between the speakers but on either side of the MLP.Fix layout of equipments and speakers, so high quality metal conduits with wider cross section can be installed under the floor. If your room is big, you may go for layout putting preamp, sources etc on side of listening chair position and run IC from preamp to amp near to speakers . This takes longer ICs , may be 4 to 6 mts. But it's worth it, as I experience it.
Any reason why the conduits should run in the floor and not in the walls? I would prefer full carpet instead of wooden flooring. Any use of wood over carpet?Consider 1/2 to 3/4 inch teak wood planks for flooring, with conduit s running under them. Not to go for synthetic or artificial material which look like wood but it's not and have extremely low or zero porosity or sound absorption.
Carpet tiles in my mind . Each piece can be cleaned/washed separately.If you are going for full carpet, go for 1mm of foam which will add a nice cushion feel when you walk over. Use a carpet material thats easy to clean and maintain. For me, that was one of the best decisions made and everyone loves it as its easy to sit in the floor when there is a shortage of seats.
I mean either left or right. Probably right side as on left there would be huge windows at around 6 feet height.System distributed on both sides will probably require very long lengths of interconnects
Thats Interesting and matter of research thanks for bringing this up.The solar plant will probably not provide large dynamic power .... Not sure yr system will sound good.
Power cables may conveniently run either under the floor or in walls, but ICs, spkr cables, almost must run under the floor to make them of shortest length possible. And to keep floor clean of cables.Most probably, I am gonna install a solar power system and will see if its possible to have a dedicated line from the plant directly.
Good point.Power cables may conveniently run either under the floor or in walls, but ICs, spkr cables, almost must run under the floor to make them of shortest length possible. And to keep floor clean of cables.
