designation
hello all , a newbie here, tried searching for a thread with same heading , but couldn't find so starting one, would like to know whether a diy speaker can be made better than a branded speaker? please do help.
Original designs require indepth knowledge, research and back-breaking experimentation.
I would rater say completing work from the carpenter is the biggest pain...
the drivers used in original branded speakers will be specially ordered by the brand company so they are well matched ones. even the xover components will be matched pairs. when u try to purchase same components and try to replicate its not going to sound similar to the original as you may not have received matched components. moreover there is no guarantee that specs of original components are same as the ones you have!In the DIY category, there are 2 broad classes (1) replicas of branded products and (2) original designs. If you are trying to replicate a branded product with original drivers, cross overs and design specs, you can get very near to the original and if you are an expert DIYer, you can tweek accordingly to make your relica sound even better to your ears. Original designs require indepth knowledge, research and back-breaking experimentation. But if you're game for it, its always the most satisfying. Buying something branded allows you to just plug, play and listen. On another note, the marquee value of a DIY effort will be appreciated by a select few while the marquee value of your big-ticket branded speaker purchase will be far-reaching.
. would a diy speaker costing rs.50000/-[which is in trivandrum ,made by someone whose making unbranded speakers, bur assures he uses the best of components] be better than this?
DIY at times will turn out to be more expensive than purchasing a branded one if the skill levels are new. Its better to settle down for a good branded product if you are not aware of what you are doing.If you have knowledge, required skillset for carpentry, money, time and patience then go with DIY build, else buy the branded ones.
would a diy speaker costing rs.50000/- [which is in trivandrum ,made by someone whose making unbranded speakers, bur assures he uses the best of components] be better
5.Never get panic if something went wrong, can fix it yourself and be happy customer
Our Indian consumer attaches disproportionate value to brand equity.
