john_k_antony
Friends,
Do Solid State stereo amps need a good warm up every time you "cold" start it? Meaning you switch it on after they have been kept off for a while (more than 8 hours) and you have to play it for 30-45 minutes before it sounds good?
I have an Acoustic Portrait SS power amp and it needs a good 30-45 minutes of playing to start sounding good. When I do a "cold" start , it sounds very thin and bright. The bass and mid range shows up after 30-45 minutes .
I also noticed that I can hear a feeble humming sound from the speakers when no signal is fed, like a tube amp. The humming/distortion sound is heard from both the speakers.
Does the above symptoms sound like there might be a leaking / weak Cap in the amp that needs replacement?
Thanks,
John.
Thanks,
John.
