vinothkumar
Great Annamalai ji, Please buy the SVS isolations and get even better sound.. You wont regret the decision
Actually the svs isolation path isn’t required for concrete floor and a gym tile of more then 20mm will do the trick.
I actually live in the second floor. After calibrating my sub went to the first floor bedroom which is below my HT set up and couldn’t feel any rattles. Also the bass is more tight after placing it on the gym tile. What I am saying is you get the similar performance using the gym tile. May be abroad where the roof or the walls are wooden requires isolation path. A gym tile will do the job just fine may be not as effective as the isolation path but an economical alternative for Indian homesIts ideal especially for people living on the top floors. It also reduces rattle in the room & makes the bass sound tighter. Mine is a down firing subwoofer placed on a 2 inch wooden plank on a concrete floor. I feel absolutely no vibrations on the wooden plank below when it plays at half volume .
Since you are using an svs sub, it shouldn't sound boomy.
Totally Agree....for subs, more than the subs, its the room we hear. What I meant was that, since he has a sub which has a comparitively flat response, has a better chance of not sounding boomy in a particular location. I do agree that even the most expensive sub if not placed and setup properly can sound boomy.Unfortunately, that's not true. There's nothing magical about any sub that will confer on it the ability to not sound boomy in any room. The room matters and even more so in the LF.
Oh ok, we’ll then I’ll ask some one from us to get me a set when they are visiting India.Good. My suggestion is from my own experience Love4Sound. Never tried the gym tile but one thing which is to be noted is that the SVS sound path isolation is especially for the SVS subs which are the perfect suit for the weight of the subs and those work really well. Eventually, the result is mindblowing.
You can try Singapore too....although not at same price as US...it is available for 89sgd (approx 4600inr) for a set of 4.Oh ok, we’ll then I’ll ask some one from us to get me a set when they are visiting India.
Ok sure.You can try Singapore too....although not at same price as US...it is available for 89sgd (approx 4600inr) for a set of 4.
Congratulations.after a week of usage my opinion reg svs pb2000 duals
they literally rocks my room with slam
music also good overall happy with dual pb 2000
A note: the PB 2000 could be a little underwhelming when you start with it, and needs quite a few tweaks (it did at least for me) before it grows on you. It goes mighty low, never bloats, but not well known for mid bass attack or that much sought after tactile response. Since your investment looks significant, and as other FMs have mentioned, auditioning other subs too will help.
Acclaimed subs might have great reviews on the Net, but I think it is our preference for the kind of bass and our budget that finally dictate our purchase.
I was craving for that mid bass attack, and finally settled for the newly released Klipsch SPL 150. The Klipsch’ tactile response is probably a bump on the FR response curve for that frequency band, and may not be flat (accurate), but asked to choose between SVS and Klipsch, I would pick the Klipsch anytime, because that’s the bass I need - but that’s only me. An audition, as every FM says, along with your preferences, is the key.
Very Valid Point, Like every other Sub; SVS needs to be Tweaked , Positioned correctly to get the best out of it, There are no shortcuts. Most of the times you hear the Room More than the Subs. I realized this fact when a FM lugged his brand new SB2000 across the city to my place, since he wasn't hearing the effects of his bran New SVS subwoofer. We did a side by side comparison over a Spiderman BluRay with XTZ12.17. Though XTZ performed better in Comparison, the FM was quite relieved that SVS did impress in its own way. Knowing the room response in this equation, I bought two Pioneer 51w (saved a lot) and I am happy with the bass response. Though they're not as resolving as XTZ but they're enough for my HT Requirements.the PB 2000 could be a little underwhelming
@prateekatasniya , can you PM me. Curious about your suggestion of proper integration of low cost dual subs which gives good performance.These products are not sold in bulk to sell at 5% profits.
But still a few dealers seem to disrupt the market by selling products at ridiculous discounts.
Such dealers sell and are done.
A good dealer should provide technical assistance to achieve performance the product is meant for. And for this he needs to have technical knowledge.
Without good integration subwoofers sound shit.
Had experienced pb2000 at kukatpally, Hyderabad ( demo)
It sounded crap.
Its not coz the sub was bad.. its because the integrator didn't take the pain to install it properly.
The real reviewers are champions at integrating the subs.. that's why a good product gets good review.
With good integration 2 50k subs can sound better than 2 100k subs.
I know a few things are difficult to digest. But that a reality.
