for future A12P owners!
M12-A12 - diyAudio
how about the 12P? i don't mind it at all.... In fact, I am confirming it! So go ahead let the dealer know that the 12P is mine!
Great! That makes 2 of us for the 12P, which is also the minimum number required for the 12P group buy!
Have you given any thought about which cabinet design you want to use? The designs that I know of are:
(1) Pensil - floor standers (transmission line) - available free
(2) Super Pensil - floor standers (transmission line) - available free
(3) Bob brines design (transmission line) - need to be purchased
(4) Mar-Ken design - bookshelves - available free
(5) Mark Audio Double Bass Reflex - bookshelves - available free
Best,
APK
Right now the toss up is between 2 and 3...
Best,
APK
bass reflex would simply ruin the sound!
as far as i know,Please try overlook my ignorance. Are you implying here that transmission line sound output quality is by far superior to bass reflex speaker designs? Or, is it the case when only full range drivers are in consideration to be mated to different speaker housings?
1 is not for A12P.
superpencil has got quite complext bracing structure.
Mar-Ken's volume is obviously less so cant expect much bass but proven to be good for mids.
at one of forum member hemant (from bangalore) place i heard these A12p in super pencils. he has got a thread on HFV, but need to search.You mentioned elsewhere on the thread that you have heard the 12p in the super-pensil design. Was this in India? or somewhere abroad?
Best,
APK
I suggest, go with (3) Bob brines design (transmission line) - need to be purchased
yes, but again there are lot of other factors for deciding on such setup!So, if I have understood it correct, it is always better to settle for 'sealed' main speakers (either 2 or 5 speakers, as the case may be) and complement the lower end by adding a powered sub-woofer. I gather, since the 'sealed' speakers could be inefficient, sufficient higher powered amp/avr might be a requirement. Else, TL is the best way to get an exquisite yet overall vfm compromise. Right?
Sorry for the OT!
Sorry for the OT!
i guess i missed the driver details when i listened quite a bit of time back (sorry for my ignorance). yes they looked metallic, so they were obviously not 12P! unfortunately Hemant was out of country, so couldnt have a detailed audition.I guess you are refering to this thread
http://www.hifivision.com/diy/11519-building-pencil-12-series-alpair-12-a.html
This build seems to be for the Alpair 12 drivers, which are the previous version of the one we are talking about (12P). The alpair 12 drivers (version 1) were made of metal, whereas the latest one is made of paper - hence the nomenclature 12P.
What were your throughts on the sound from the Alpair12 in pensil design (which is what Hemant seems to have built)
Best,
APK
OB! thats every man's dreamthat is not correct. it is always better to have open baffle. well, I think "always" better is incorrect for any design.
exactly! any OB would require that much space for its operation. for the same reason i am keeping my hands away from OB! one possible solution (although not the best one) would be to have fullrangers in OB and sub/woofers in sealed box.I was thinking of - from GR research. but the requirement of placing them at least 3 ft away from rear wall makes it difficult placement in my living room.![]()
