help me setu p Denon1713 AVR with infinity primus home theatre
abiram
chennai
Hi guys,
i've an infinity Primus Home Theatre that was sent from dubai and now i've purcharsed a Denon 1713 avr, ive connected the speaker and woofer, when i play songs only the front speakers work, the woofer and centre speaker does not work, also im confused about connecting the woofer. should i connect the speaker wires also in the woofer? pls help.
Is it a powered subwoofer? Connect subwoofer out of the AVR to the line in of the subwoofer. You need to do audessey equalization for matching your room characterestics. Also you should select one of the DSP modes like Dolby Digital Prologic or DTS Neo6 to get sound through all the speakers and subwoofer for two channel audio inputs.
If you are playing 2-channel material, then only 2 speakers will play.
Turn on PLII (Dolby Pro Logic II) processing to convert the songs to surround.
Did you use the included microphone to run automatic speaker set-up?
